it's working now! Thanks!
F Ferrari355 New member Apr 27, 2005 #21 it's working now! Thanks! Crystalfontz LCD BlogLooking for additional LCD resources? Check out our LCD blog for the latest developments in LCD technology.
F Ferrari355 New member Apr 27, 2005 #22 I don't have something for you.. When you change locations I loose my Contrast, However just clicking on the adjustment without changing it brings it right back up.
A akweb New member Apr 27, 2005 #23 I've seen that happen when using another program that has its own brightness and contrast controls. I can add something to future versions so it will reset itself when you run it.
F Ferrari355 New member Apr 27, 2005 #24 cool we had a thunderstorm today, works great I might ask! Attachments dsc_1355.jpg 66.5 KB · Views: 760
F Ferrari355 New member May 2, 2005 #25 having another problem.. I by mistake when I formatted my pc I set it to the wrong Com port, Now everytime I try and start the program it says.. "Run-Time error '8002': Invalid Port number"
CF Tech Administrator May 2, 2005 #26 Should be able to change the port number as shown here: http://www.crystalfontz.com/software/usb_change_com_port/USB_Change_COM_Port.html
A akweb New member May 2, 2005 #27 That or you can change the port value in the registry (assuming you are using CFA-634 Weather and are comfortable navigating the registry): HKEY_CURRENT_USER\Software\VB and VBA Program Settings\CFA634Weather\Port\value hope that helps! -AK
G Grentz New member Jun 17, 2005 #31 You could always use www.rssweather.com and then find your area, and show it as an rss feed on your LCD
