Variable Brightness
apman
A while back I remember seeing an IC that will output different voltages depending on the data it receives.
It works much like a voltage regulator except that it is also connected to a microchip's data lines to control the voltage.
Does anybody know what this device is called? Or where can I get one?
Thanks in Advance
Two ways I know of off hand:
DAC = digital to analog converter
PWM + LPF = pusle width modulator + low pass filter
First one is accurate and quiet, second one is cheap.
apman
Thanks for your reply.
After looking through some datasheets on the IC I'm using, I would technically be able to use the DAC on the IC, providing that it provides enough power.
So hopefully, this will work as I want it too.
specialk
Don't draw too much current though!
Wire it up to a adjustable voltage regulator (like the LM317) if you plan on driving higher current draws.
-special [k]
