[TEA]Towle
http://www.mbreview.com/links.php?op=viewslink&sid=283One of the best things about this board is the availability of ten USB ports. You have two on the pack panel with four headers on board - each supporting two USB ports and every one of them is USB 2.0 compliant
How do I connect Crystalfontz to the motherboard? I have only used two headers on the motherboard -one for a rear 4 port hub and one for the front mounted USB port (Antec 1000 AMG Plus View SOHO ATX File Server Case)
The connections are different, I would want to connect direct to the motherboard. is there some sort of adaptor? I don't want to run the cable outside of the case or through the back of the case into one of the free usb slots on the rear 4 port hub.
