OLED CFAL2004A-Y
Ferrari355
I have a question when the datasheet says N/C does it mean it's not connected on the PCB or not meant to be connected with the pins?
CosmicVoid has it right:
Certainly, you should make no connection to a pin marked NC. It might be a test input or output, for instance.
Sometimes, the pin also makes no connection inside the component.
Ferrari355
So in replacing something that was a backlit LCD just break off pins 15,16 and 3 right? Felt good ordering from CrystalFontz again :) wow I've been here since 2001
So in replacing something that was a backlit LCD just break off pins 15,16 and 3 right? . . .
By "breaking off pins", will you damage what this is going into? Looking at the traces in the photos of that OLED, it appears that 15, 16 and 3 are all of the "no connection inside the component." variety, so it should not hurt to connect them. (he says, in stark contrst to his earlier advice :rolleyes: )
. . . Felt good ordering from CrystalFontz again :) wow I've been here since 2001
Always welcome ! What is the project?
Ferrari355
I mean it would better to leave the pins on but I just want to be sure but it looks like it would be fine..
I would be replacing a white/blue LCD to OLED on a 3D printer it seems this OLED is a tad bit larger but a new housing I think should take care of it.
