I've tried the screens that comes with CC2 and I have seen the screen forum but I can't find nothing that
send 633 RPMs and temps to MBM or to the screen. The Speedfan screens read the motherboard temps, voltage etc. and send them to the lcd.
I like to use MBM because:
I can see all the 633-RPMs, 633-temps, motherboard temps voltage etc, together in MBM dashboard screen on my monitor;
it can monitor them with alarms and eventually
hibernate the PC.
The alarms option in the CC2 is buggy; I have tried to add manually a line in lcd_633.ini
temp01_name="Maxtor"
temp01_uid="0xBE00000040C8A028"
temp01_alarm_min=10.000000
temp01_alarm_max=20.000000
temp01_enable_alarms=1
temp01_shutdown_on_alarm=1
temp01_id_name=1712521695
temp01_id_alarm=1088307391
temp01_id_temp=1670665293
temp01_id_temp_min=2382929895
temp01_id_temp_max=1487468509
so the PC Shutdown after 10 seconds, but it don't give me any previous alarm or option to manually stop the shutdown, and it don't turn off the PC ( .. now it's possible to turn off the computer ...).
Actually MBM has options that CC2 have not; so if it's not possible to use MBM together with CC2, like I used to do with old 633 NT service, it would be nice if it could be added in the next realise of CC2:
1) sound alarms
2) run a program on alarm (shutdown/hibernate)
3) a dashboard screen, a sort of big virtual lcd, that can display all the 633 readings and the Speedfan readings
4) eventually, fan regulation based also on Speedfan temps.
thanks, Giulio
