Large LCD segment: where to buy
kalustal
Hi
I would like to build a cheap display to show information available on a sailing boat.
Specialized companies are selling these things for a very very high price...
What I would need would be a simple 7 segments 3/4 digits LCD module, with char height of 100mm, backlight, negative, and low power?
Where could I find it?
Here is a picture of a high end product, selling for more than $1000!
attachment.php
Thanks in advance,
Jerome
You could use a graphic display, and make some large font characters for the numbers. That would require a lot of programming on your part, though.
kalustal
Thanks for that suggestion, but it will be difficult and costly... Isn't there any body who have an idea on that?
I would agree with cosmicvoid, you are going to send a lot of work and time on other parts of the project, why skimp on the LCD? Graphic LCDs give you much better flexibility. Segment LCDs are used for one reason -- cheap in high volume.
But in any case, you can get something like this:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=153-1016-ND
attachment.php
(that is just one example, they have many variants)
kalustal
Yes, I fully agree with that, segment lcd displays should be cheap when they are produced in long standard runs. And what I'm looking for is just a large (digit height 70 to 100mm) 4 digit 7 segment lcd module! I could even pay something like 50$ on it... I just need to find one !! Then the electronics and box for it should be quite simple, and yield something working for one 10th of the price of high end products! I am even pretty sure that there might be a quite nice market for such things, apart from my DIY project...
Jerome
kalustal
For the $100 graphic LCD, does it have a high contrast ?
Otherwise, I also like the idea of using a large clock lcd... I will work on it!
rmteo
This is done with a 128x64 Graphic LCD.
attachment.php
rmteo
Here is another example using a 240x128 GLCD. The largest characters are about 1.3in. (33mm) tall.
attachment.php
