I've just got two lcd (632 serial adn 632 usb).
They both work fine when I use the software from crystalfontz.
Now I wanted to use labview to control them. For the 632 serial there is no problem in making it working (actually I'm using a cable converter from usb to serial and everything is fine). When I try to use instead the lcd 632 usb, there are some problems. In fact when I pass a string of characters, I obtain very weird characters visualized on the lcd. Moreover there is no way to control the backligth or contrast (when passing \015\100\n for example weird chars appears too).
Note that labview sees the ports for the communications without any problem.
Any suggestion? If someone is using labview and can help that will be greatly appreciated.
-Claudio
-Claudio
