There is any software (linux) to control cfa 635 leds?
solved
for lcdproc:
"output <number>"
the led-color is set by a bit-mask: 1111 1111
first block sets the color of the led to green, the second block to red.
if both --> orange
<number> is the byte or hex value of the bit-mask
thanks
Example 5.8. Pyramid: How to use the LED output from the client
telnet localhost 13666
hello
output 67
will light up LEDs 3, 4 and 9.
output 0
will clear all LEDs.
there is anyway to get the actual states of the leds? . . .
. . . "huh? Invalid command "input"" . . .
. . . I had to make an code to load (at beggining) and to save (at finish) the "last_state", so I can change just a specifc led, and not the 4 ones
