programming CFA-635 LED
delphi99
Hi @all,
I've googled but not found...
Is there a documentation about programming the 4 led on a CFA-635? I want to use it in lcdproc, but it looks like I have to code it myself.
tnx Frank
delphi99
solved :)
for lcdproc:
"output <number>"
the led-color is set by a bit-mask: 1111 1111
first block sets the color of the led to green, the second block to red.
if both --> orange
<number> is the byte or hex value of the bit-mask
thanks
OK, good you have it solved. Thanks for posting the solution to driving the CFA-635 LEDs from LCDproc.
