How to control CFA 635 LEDs in LCDProc?
p4blu
sorry, but I cant understand it
I use lcdproc, and make my code in bash, acessing telnet etc..
its just digit this at telnet window?
I am no expert on LCDproc . . .
From this page: http://lcdproc.sourceforge.net/docs/current-user.html
Example 5.8. Pyramid: How to use the LED output from the client
telnet localhost 13666
hello
output 67
will light up LEDs 3, 4 and 9.
output 0
will clear all LEDs.
Based on that and the previous quote I think this:
output 15
( 0b 0000 1111 ) should make the all the LEDs red.
output 240
( 0b 1111 0000 ) should make the all the LEDs green.
output 172
( 0b 1010 1100 ) should make the one orange, one green, one red, and one off.
Can you try those over telnet and see if the LEDs change?
p4blu
there is anyway to get the actual states of the leds?
i want to make and script like
script -l [0,1,2,3] -c [red,green,amber]
but I need to know the actual state
there is anyway to get the actual states of the leds? . . .
The module's firmware command set is able to return the state of the LEDs, but I do not know if LCDProc actually supports the operation. Is there an "input" that corresponds to the "output" function?
p4blu
hello,
unfortunately no
"huh? Invalid command "input""
I had to make an code to load (at beggining) and to save (at finish) the "last_state", so I can change just a specifc led, and not the 4 ones
p4blu
#!/bin/bash
led=$1
color=$2
control=(`cat /tmp/last_state`)
if [ "$control" == "" ]; then
echo "null file, changed to 00000001\n"
echo "0 0 0 0 0 0 0 1" > /tmp/last_state
else
echo "last state recover:"
echo ${control[@]}
fi
if [ $led == "led1" ]
then
colorbit1=3
colorbit2=7
elif [ $led == "led2" ]
then
colorbit1=2
colorbit2=6
elif [ $led == "led3" ]
then
colorbit1=1
colorbit2=5
elif [ $led == "led4" ]
then
colorbit1=0
colorbit2=4
fi
if [ $color == "green" ]
then
colorbit1_value=0
colorbit2_value=1
elif [ $color == "red" ]
then
colorbit1_value=1
colorbit2_value=0
elif [ $color == "amber" ]
then
colorbit1_value=1
colorbit2_value=1
elif [ $color == "off" ]
then
colorbit1_value=0
colorbit2_value=0
fi
control[$colorbit1]=$colorbit1_value
control[$colorbit2]=$colorbit2_value
echo "new state update:"
echo ${control[@]}
control2=${control[@]}
echo $control2 > /tmp/last_state
bin="${control2// /}"
p4blu
sorry for the delay..
copy this code, into a program.sh
chmod +x program.sh
mv program.sh /usr/bin/program.sh (so you can access from any folder...)
then use:
program ledX [1-4] color [green, red or amber]
