Help interfacing a 16X2 parallel display with a PIC 16F628
akleindolph
Help with my LCD and microcontroller!!!
I have succussfully diplayed text on a number of HD44780 compatible parallel LCDs using the simple "LCDout" command in PicBasic Pro, but I can't seem to get my crystalfontz display to work using this same technique. I believe that my hookups are all correct but I do not know how to make the code work. Does the "LCDout" command only work with certain LCD panels? If not, are there any code resources for a sucessful PICBASIC/Crystalfontz relationship? The display I have is CFAH1202A-NYA-JP.
Thanks!!!!
The CFAH1202A series should act like any other "HD44780" display.
Make sure pin 3 is at around 1v (Vlcd = 4v).
Make sure the wiring is OK. Check the timing.
akleindolph
Thanks! I'll look over it some more. As far as timing: I am using a 4mhz crystal and 500ms between startup and commands. Should I increase/decrease either of these?
Thanks so much!
-Andrew
