akleindolph
Help with my LCD and microcontroller!!!
I have succussfully diplayed text on a number of HD44780 compatible parallel LCDs using the simple "LCDout" command in PicBasic Pro, but I can't seem to get my crystalfontz display to work using this same technique. I believe that my hookups are all correct but I do not know how to make the code work. Does the "LCDout" command only work with certain LCD panels? If not, are there any code resources for a sucessful PICBASIC/Crystalfontz relationship? The display I have is CFAH1202A-NYA-JP.
Thanks!!!!
Thanks!!!!
