Confused
dharans69
Hi all,
I want to use a graphical LCD such as the "Wide Temperature 128x64 Graphic LCD Module" or "Compact 128x64 TAB Graphic LCD Module", or Wide Temperature 240x128 Graphic LCD Module.
Now what I would like to know is:
Are these Graphic LCD's compatible with the motherboard monitoring software etc, If so which software. Isit as straight forward as plug n play?
Also as a general query, if all my serial and parallel ports are being used, is it possible to use the parallel to USB or serial to USB converters?
TIA.
Dharans
This is theoretically possible with something like LCD Studio or PowerLCD, though plug and play is not going to happen.
Hacking together a USB to parallel is *theoretically* possible, though the process sounds like it'd be a real headache.
All things considered you'd probably be better off putting together a 634 kit here:
http://www.crystalfontz.com/products/select_kit.html
