Hi all,
I want to use a graphical LCD such as the "Wide Temperature 128x64 Graphic LCD Module" or "Compact 128x64 TAB Graphic LCD Module", or Wide Temperature 240x128 Graphic LCD Module.
Now what I would like to know is:
Are these Graphic LCD's compatible with the motherboard monitoring software etc, If so which software. Isit as straight forward as plug n play?
Also as a general query, if all my serial and parallel ports are being used, is it possible to use the parallel to USB or serial to USB converters?
TIA.
Dharans
TIA.
Dharans
