I want to select an LCD for pSOC processors from CYPRESS.
Here is the description of thier LCD interface
"Functional Description
The LCD User Module uses a single I/O port to interface to an industry standard Hitachi HD44780A LCD controller. This type of display has a simple interface consisting of 8 data bits, read/write (R/W), register select "RS," and an enable "E" signal. To reduce the number of pins required, the 4-bit interface mode is used. The LCD to PSoC block diagram and the table below, describe the 4-bit interface connections."
Here is my question:
Can I use CFAH0802A-NYA-JP LCD
and use it in 4 bit mode?
Regards,
Farhad Gholami
Hardware Engineer
On some displays, DB0, DB1, DB2, and DB3 may need to be pulled down to Vss with a 10K resistor. Pulling these signals low ensures that the 4-bit mode is entered properly.
Regards,
Farhad Gholami
Hardware Engineer
