CFA635 Dimension Conflicts (PDF vs eDrawings)
I'm designing a 1RU case with a CFA635 LCD and I've come across some issues in regards to the dimensions!
The measured dimensions (eDrawings) do not match the dimensions supplied in Crystallfontz drawing number CFA-635KSP02 (page 12 CFA635-TFE-KS.pdf) or the website.
Are the PDF / Website drawings accurate? Given the disclaimer on the eDrawings page I gather that is there is an issue it is likely to be in the eDrawings as opposed to the PDF.
My main issues are the following dimensions...
Edit: Also I don't think that the eDrawings LCD Keypad is centred around the screw holes vertically (14.48mm from 'tick' button to upper screw holes, and 15.52mm to the lower screw hole; dimension taken in the Y (up/down) plane only). The PDF / Website drawings don't give dimensions for the keypad vertical orientation, am I correct in assuming that the 'tick' button is on the centre line of the PCB (i.e. 15mm between the centre of the 'tick' button to either screw (upper or lower))?
Another question the chassis mounting bracket for the 635 uses 4-40UNC studs with spacers and nuts to attach the LCD to the chassis. The PCB has 5 x 2.50mm holes in it for mounting, however isn't the OD of 4-40 UNC ~2.85mm? How does this fit through the 2.5mm holes on the LCD PCB!
Are the PCB holes really 2.5mm? Or do you drill them out to suit 4-40UNC or???
Cheers
Wilbo
I understand that they are for visualization only, but they seem like inconsistencies worth bringing up!Crystalfontz: CFA635 eDrawing Webpage said:Disclaimer: These models are intended for visualization only, not design. These drawings are accurate to the best of our knowledge. However these drawings are not design drawings but were generated from the 2d drawings provided in the datasheet and measurements of sample parts. Please verify your design using the 2d drawings and actual parts. Please let us know if you find any errors or inconsistencies in these drawings.
Cheers
Wilbo
