Bug
BigTy
after going to 100p2 i get this error ive also tried going back to the old 99 but it still comes up
Joaquin
Ty,
I had to reference the suggested registry key deletion in this thread when I upgraded.
https://forum.crystalfontz.com/showthread.php?s=&threadid=1369
You might be running into conflicts with the values that each version you've installed and uninstalled has written to the registry.
Also, I repeatedly ran into errors like the one you posted when I was goofing with Gaming Info and trying to install newer CC versions.
J
BigTy
WELL after doing was was said i still get that problem here is something odd i only get it after a long period of time like many hours can we take a look at this
BigTy
CC any word on that fix. i did what i was told to do and it came back. so at the moment i cant even use my display.
Your running V1.00pr3 right?
create a shortcut to the CrystalControl.exe, and run it with the command line option "/debug".
Itll create a log file in c:\
It might help find whats creating the error.
Just make sure you dont always run CC with /debug.... the log file will be HUGE.
BigTy
so far so good. completly uninstalled the last download and put 100pr3 and its working go at this point. ill keep an eye out on it. still a no go on the medal of honor. and lastly i dont know if this was answered but UT2K3 when will that be added.
BigTy
ok that didnt work so well. i think i may need a little more info on that command line thing if you dont mind.
Ok.
Step by step:
- Go into the dir where you installed CrystalControl using Explorer.
- Right click on "CrystalControl.exe", click "Create Shortcut"
- Right click on the shortcut that was just created, click "Properties"
- Go to the "Shortcut" tab, if its not already selected.
- Add to the end of the text in the "Target" line, "/debug" (without the quotes).
- Run CrystalControl by double-clicking the shortcut.
BigTy
i found out what i was doing wrong for got the stupid space between the end of the line and the /debug
BigTy
heck after running in Debug im not getting the errores i hate when stuff like this happen. like i made the whole thing up
BigTy
this part is normal i saw it many many many times
TMainForm::UTimerTimer - in
dateinfo::Update - in
dateinfo::Update - out
mbminfo::Update - in
mbminfo::ReadSharedData - in
mbminfo::ReadSharedData - out
mbminfo::Update - ReadSharedData failed... out
gameinfo::Update - in
gameinfo::Update - out
perfmondata::Update - in
perfmondata::Update - out
display::Display - in
display::Display - out
TMainForm::UTimerTimer - out
this part looks funny
TMainForm::WndProc - in
TMainForm::WndProc - out
also this
BigTy
here is what you asked for
BigTy
maybe this might help im not swtinging screens and its not having ANY problems. so mow i have to either say its one screen that is causing it OR the process itself.
