Black aluminum bracket?
GreenMarine
Do you guys have a black aluminum bracket for the 634 ? I have a black aluminum Lian-Li PC-75B and would like to install a 634 in the upper two drive bays. However, I'd prefer to have an aluminum bracket, instead of a black one.
Would you guys anodize or provide a black aluminum bracket by special order?
Is there any demand for this kind of product?
Firehed
I'd like one too and I'm sure I'm not alone so there must be a demand. Although I kinda doubt the LCD would just pop right out of the existing bracket and fit without something breaking :(
It is a moderately close match to the Lian Li black cases though. I mean it'll be somewhat obvious in pictures with a flash and whatnot, but it blends in pretty well as it is.
GreenMarine
We'll see. I ordered the black bracket version. I hope it blends in okay. I'm building a mega rig. FX-53, K8N Neo2 Platinum, Ballistix PC3200 ultra low latency ram, 10k rpm raptor drive, etc. Visuals are key as well.
If it doesn't match, I may be able to hand make some kind of solution.
GreenMarine
Woot!
I just got my LCD. I won't be able to power it up until early next week, but I carefully installed it and put a "do not touch" sign on it.
The black plastic matches perfectly with the Lian-Li black aluminum under all but the closest inspection. In fact, it puts the CoolerMaster black metal parts to shame, which are just off-black enough to be visibly different.
I'm excited to code for this. I'm a poker fanatic and I think I may code a small app to display some poker related stuff, like my stats from my PT database, among other things. Hehe.
