I recently bought a 635 with an aluminum bracket from Crystalfontz. So far I am very pleased with it.
However, I'm going to use this display in a casemod, and I need to dismantle the aluminum brackets plastic cover (the thin plastic that protects the screen area) in order to alter the appearance like I want to.
The problem is that this plastic is glued very very firmly in place. Trying to remove it by force seems useless, since the (very thin) aluminum front only bends and is destroyed in the effort. My best attemts at disolving the glue with chemicals have also not been effective.
So, the solution is actually very simple. I need to buy a bracket just like the ones you have, but witohut the plastic cover glued onto it.
I don't know if you make these yourselves, or have them made by another company, but logically it should be possible to get hold of one of these that aren't fully "assembeled" (ie. the plstic not glued into place).
It would really mean a lot to me if someone could check if this is possible to aquire, or (in the case that the brackets are not manufactured in-house) could give me the contact information to whoever makes them so I could enquire the directly.
The casemod in question is reasonably high-profile and wil be featured on quite a few enthusiast forums in the form of a worklog (in roughly a month or so if all goes according to plan), so if support can help me get hold of one of these, I will make sure to put crystalfontz up as a sponsor in my worklog. I hope this can provide some insentive for accomodating my slighlty unusual request![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
EDIT: Clarification, this is the bracket I am talking about:
http://www.crystalfontz.com/products/635bracket/index.html
The normal aluminum (not black) version. with or without logo.
Of course, don't hesitate to ask if something is unclear. I will do my best to clarify![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Sincerely
-Stigma
PS: contact through PM is fine if you want to give me contact infomation for a sub-contractor (if this is the case).
Sincerely
-Stigma
