I just got the new version of the Service. I want to list the bugs here:
- Settings are not saved properly.
I think the software have great problems writing the settings to the ini-file. I attached both ini-files (in one txt-file). The only change i made was setting COM Port from COM1 to COM2. Before there were all entrys ok. But after that -> look into the ini.
I can delete the ini -> set all settings in the 633-Monitor -> then save -> works
But when I cannot change anything with the 633-Monitor, I must change it directly in the ini-File
- CrystalControl (V1.00) doesn't work with the new service, in the readme you say CC 1.01 is supported, but V1.01 is not yet available, I think it will be released in the next days
- In the Power On Settings the "Enable Fan Power Fail Settings" is grayed out
