Hi all,
I want to start playing with the CFAF320240F-T-TS Crystalfontz touchscreen display. I will use a microcontroller to interface with the LCD display. The problem that I am having is that the connectors for this display, like the HFJ150CT-ND, have a 0.5mm pitch making it almost impossible to solder any cable leads to the pins.
So, how I am going to test the display if I can't solder any cables to the connector pins? Are there any pre-made boards for testing these LCDs? Do I need to design a PCB board and send it to a PCB manufacturer in order to test the display?
Any suggestions are greatly appreciated. Thank you for your help.
Robert
Robert
