631 Lcd
yaman
i connected my LCD to the USB on my mother board, after switching ON the PC, i did not see anything on the LCD screen and did smell something strange so immediately switch it off.
i have USB1 and USB2 on my motherboard, i connected the cable to USB2 and make sure to be connected as per the mother baord manuel:
+5v -D +D Ground
can someone advise what might be wrong
thanks
yaman
LCD 631
this is how the USB looks like on thr motherboard as the attched word file, but physically at the top there is 4 pins and at the bottom there is 5 pins,
can you explain where to connect the 4 pins, is the on the top one or the bottom one.
thanks
If it smelled strange, then the +5v and Ground probably got reversed.
Does the display still work if you use the beige USB cable?
Can you get us a link to the manual?
yaman
LCD 631
can you provide an e-mail address as i tried to attached a file to you but it never worked, so provide an e-mail and i will send you the the page related to the USB.
waiting for your e-mail
thanks for replying
yaman
LCD 631
i think i connected it the proper way now as:
GRD + - VCC
but still telling me the LCD is not connected,
do you think the LCD is busted
your reply is highly apreciated
