I have been using a 16x2 LCD display no. MC1602F-SYR for some time and
I think I understand its features. However, I hit a new one today.
I am sending data to the display 4 bits (one nibble) at a time, and I
know I must wait 40us between each transmission. What I am doing is
sending the first nibble, going off to do something else, and then
coming back to send the second nibble. The sequence is:
Set up first nibble
Enable LCD (make EN = 1), wait short time, disable LCD (make EN = 0)
Do something else that takes at least 40us
Set up second nibble
Enable LCD, wait short time, disable LCD
The problem arises when I am doing something else. The LCD is on
a bus so while I am doing something else its inputs may change.
However, so long as EN = 0 I would have thought that would be OK.
But it's not.
I have reduced the problem to this short section of assembler
(PIC18F4550):
(**) Problem instruction
The instruction time is 83.33ns and I am sending a special
character I made up in CG RAM address 0.
This fails. The reason is that I change R/W half way through (see (**)).
It also fails if I change RS half way through. I can change DB7-4 without
a problem. If I replace the "btg LCD_R_W" with a "nop" it all works fine.
I would really like to be able to do something else between writing
each of the nibbles because I cannot afford to wait for 40us doing
nothing. Is there any way around this problem?
Martin
Set up first nibble
But it's not.
(PIC18F4550):
bcf DB7 ; Set bits DB7-4 to 0000
bcf DB6
bcf DB5
bcf DB4
bcf LCD_R_W ; Make R_W = 0
bsf LCD_RS ; Make R/S = 1
nop ; Short extra wait to ensure data is stable
bsf EN_LCD ; Set enable bit, EN_LCD
nop
nop
nop
nop
bcf EN_LCD ; Clear enable bit, EN_LCD
call Delay20us ; 20us delay. Half of 40us
[COLOR="Red"]btg LCD_R_W ; Toggle R/W. EN is 0 at this point (**)[/COLOR]
nop
[COLOR="red"]btg LCD_R_W ; Toggle R/W again. EN is still zero (**)[/COLOR]
nop
call Delay20us ; 20us delay. The other half of 40us
bcf DB6
bcf DB5
bcf DB4
bcf LCD_R_W ; Make R/W = 0
bsf LCD_RS ; Make RS = 1
nop
nop
nop
nop
Martin
