timeouts on 635
deltaxfx
I am having a strange problem with my 635. I have made a lot of changes to the original test code for the 635. The odd part is when I first turn my computer on and plus the 635 in and try to run my code (writes text to the display) I get Timed out waiting for a response. Which is the timeout error from the test code. I test for a time out after each line of text I write to the display. I can try running my program over and over with no success. But if I run the original 635 test program it will work fine. Then after I have run the original 635 test program I can run my program with no problem.
Any ideas?
BTW both programs give me a success for opening the usb port at 115200. I am running both as root. The program must be running because the time out error is reported, just nothing seems to be making it to the LCD. I have to run the original program then mine works fine.
Sounds like you might not be setting the COM port up correctly.
IIRC, windows keeps the last applications com port settings until they are changed, so that might explain why your app works after the other.
I use:
GetCommState(com_handle, &dcb);
dcb.BaudRate = baud_rate;
dcb.fBinary = TRUE;
dcb.Parity = FALSE;
dcb.fOutxCtsFlow = FALSE;
dcb.fOutxDsrFlow = FALSE;
dcb.fDtrControl = DTR_CONTROL_ENABLE;
dcb.fDsrSensitivity = FALSE;
dcb.fTXContinueOnXoff = TRUE;
dcb.fOutX = FALSE;
dcb.fInX = FALSE;
dcb.fErrorChar = '\0';
dcb.fNull = FALSE;
dcb.fRtsControl = RTS_CONTROL_ENABLE;
dcb.fAbortOnError = FALSE;
dcb.ByteSize = 8;
dcb.Parity = NOPARITY;
dcb.StopBits = ONESTOPBIT;
SetCommState(com_handle, &dcb)
Oops... Linux.
tcgetattr(com_handle, &term);
//input modes
term.c_iflag &= ~(IGNBRK|BRKINT|PARMRK|INPCK|ISTRIP|INLCR|IGNCR|ICRNL
                |IUCLC|IXON|IXANY|IXOFF|IMAXBEL);
term.c_iflag |= IGNPAR;
//output modes
term.c_oflag &= ~(OPOST|OLCUC|ONLCR|OCRNL|ONOCR|ONLRET|OFILL
                |OFDEL|NLDLY|CRDLY|TABDLY|BSDLY|VTDLY|FFDLY);
term.c_oflag |= NL0|CR0|TAB0|BS0|VT0|FF0;
//control modes
term.c_cflag &= ~(CSIZE|PARENB|CRTSCTS|PARODD|HUPCL);
term.c_cflag |= CREAD|CS8|CSTOPB|CLOCAL;
//local modes
term.c_lflag &= ~(ISIG|ICANON|IEXTEN|ECHO|FLUSHO|PENDIN);
term.c_lflag |= NOFLSH;
//set baud rate
cfsetospeed(&term, brate);
cfsetispeed(&term, brate);
tcsetattr(com_handle, TCSANOW, &term);
