I have the CFAF176220U-020T TFT display with the OTM2201A controller. I want to send simple Text to the display. The back light turns on, and this is as far as I got so far. The sample code that I have uses an SD card, but I don't need to display pictures or motion, just want to send text and change the color on the screen. Any help would be great, especially some very simple code. I'm using the PIC18f4520, with MPLAB and the MPLAB C18 complier (using C).
Port Assignments:
PORTC: DB0-DB7
PORTD: D0=/Reset, D1=/RD, D2=/WR, D3=RS, D4=/CS, D5= BL EN, D6=IMO
Here is what I have so far
Thank you
Heath
(moderator adds code formatting.)
Port Assignments:
PORTC: DB0-DB7
#include pic18f4520
#pragma config LVP=ON
//#pragma config OSC = INTIO67
void write_command(unsigned char command)
CLR_CS; // chip selected
CLR_RS; // set to write to the control registers
SET_RD; // not reading
SET_WR; // not writing yet
LATD = 0x07; //chip selected, set for command (RS), (RD) not reading, (WR) not writing
LATC=0x00; // write the command to the port
LATD = 0x03; // bring write line low, clock in the command
LATC=command;// write the command to the port
LATD = 0x19; // unselect chip, set for data
void write_data(unsigned char data_h, unsigned char data_l)
LATC=data_h; // write the command to the port
LATC=data_l; // write the command to the port
void display_color(unsigned char data_h, unsigned char data_l)
unsigned int i, j;
write_command(0x20);
write_data(0x00,0x00);
write_command(0x21);
write_command(0x22);
for(i=0;i<220;i++)
for(j=0;j<176;j++)
write_data(data_h,data_l);
void delay()
int i;
for (i=0; i<3000; i++)
void initialize_display()
LATD = 0x00; //Reset active low
delay();
LATD = 0x01; //Reset off
delay();
delay();
write_command(0x11); // Power Control 2 (P22, OTM2201A Datasheet)
write_data(0x00,0x18);// Booster circuits not started automatically, controlled through PON0-3
// Generate VCI1, VCI1 = +2.58v
write_command(0x12); // Power Control 3 (P22-23, OTM2201A Datasheet)
write_data(0x00,0x00);// Generate VGH VCI1 x 5 (13.75v) / VGL VCI1 x -3 (-8.25v)
// Freq. of step up 1 = 1:4, Freq. of step up 2 = 1:2, Freq. of step up 3 = 1:4
write_command(0x13); // Power Control 4 (P23-25, OTM2201A Datasheet)
write_data(0x00,0x63);// clock cycle of external (RGB) interface (as default, unused)
// Gamma voltage (GVDD < AVDD (VCI1*2)-0.3v) 1100011 = GVDD Voltage +4.45v
write_command(0x14); // Power Control 5 (P14, OTM2201A Datasheet)
write_data(0x55,0x6A);// VCOMG = 0 ( Amplitude of VCOM = |VCOMH-VCOML| ), VCOMH = GVDD x 0.8690
// VCMR = 0 (VCOMH determined by VCM6-0), VCOMH = GVDD x 1.074
write_command(0x10); // Power Control 1 (P21, OTM2201A Datasheet)
write_data(0x08,0x00);// Constant current in op-amp Medium Fast 1
// Not in stand by, not in deep stand by
delay();
write_data(0x01,0x18);// Start booster circuit 1
delay();
write_data(0x03,0x18);// Booster circuit 1 on, start VGH circuit
delay();
write_data(0x07,0x18);// Booster circuit 1, VGH on, start VGL circuit
delay();
write_data(0x0F,0x18);// Booster circuit 1, VGH, VGL on, Start VCL circuit
delay();
write_data(0x0F,0x38);// Booster circuit 1, VGH, VGL on, Start VCL circuit
// Start amplifier circuit, Generate VCI1, VCI1 = +2.58v
delay();
write_command(0x07); // Display Control (P17, OTM2201A Datasheet)
write_data(0x00,0x12);// FLM output disabled
// Gate output Enabled, Normally black
write_data(0x00,0x1A);// FLM output disabled
// Gate output Enabled, 8 color mode selected, Normally black
write_command(0x01); // Driver Output Control Register (P14, OTM2201A Datasheet)
write_data(0x01,0x1C);// Decrement Address counter
// 528x220 dots (176xRGBx220)
write_command(0x03); // Entry Mode (P16, OTM2201A Datasheet)
write_data(0x10,0x30);// BGR (reversed color bits)
// Increment automatically the address counter
write_data(0x00,0x00);// FLM output disabled
// Gate output disabled
write_command(0x08); // Blanking Control (P18, OTM2201A Datasheet)
write_data(0x08,0x08);// 8 lines for the front porch
// 8 lines for the back porch
write_command(0x15); // VCI Period (P28, OTM2201A Datasheet)
write_data(0x00,0x20);//
// Sn=2, Vcom1=1/2, Vcom2=2/1, RGB=16dot clock
write_command(0x36); // Horizontal Window Address 1 (P32, OTM2201A Datasheet)
write_data(0x00,0xAF);// Set the horizontal start position of a window for memory access
// 175
write_command(0x37); // Horizontal Window Address 2 (P33, OTM2201A Datasheet)
write_data(0x00,0x00);// Set the horizontal end position of a window for memory access
// 0
write_command(0x38); // Vertical Window Address 1 (P33, OTM2201A Datasheet)
write_data(0x00,0xDB);// Set the vertical start position for memory access
// 219
write_command(0x39); // Vertical Window Address 1 (P33, OTM2201A Datasheet)
write_data(0x00,0x00);// Set the vertical end opsition of a window for memory access
// 0
write_command(0x50); // Gamma Control (P34, OTM2201A Datasheet)
write_data(0x00,0x01);
write_command(0x51); // Gamma Control (P34, OTM2201A Datasheet)
write_data(0x02,0x08);
write_command(0x52); // Gamma Control (P34, OTM2201A Datasheet)
write_data(0x08,0x05);
write_command(0x53); // Gamma Control (P34, OTM2201A Datasheet)
write_data(0x04,0x04);
write_command(0x54); // Gamma Control (P34, OTM2201A Datasheet)
write_data(0x0c,0x0c);
write_command(0x55); // Gamma Control (P34, OTM2201A Datasheet)
write_data(0x00,0x0c);
write_command(0x56); // Gamma Control (P34, OTM2201A Datasheet)
write_data(0x01,0x00);
write_command(0x57); // Gamma Control (P34, OTM2201A Datasheet)
write_data(0x04,0x00);
write_command(0x58); // Gamma Control (P34, OTM2201A Datasheet)
write_data(0x11,0x08);
write_command(0x59); // Gamma Control (P34, OTM2201A Datasheet)
write_data(0x05,0x0c);
write_command(0x0F); // Oscillator Control (P21, OTM2201A Datasheet)
write_data(0x0F,0x01);// Freq = 453kHz x 1.29
// Oscillator on
write_data(0x00,0x17);// FLM output disabled
// Gate output Enabled, Normal display, gate on, vcom on, display on
write_command(0x22); // GRAM Data (P30, OTM2201A Datasheet)
void main ()
int loop = 1;
initialize_display();
while (loop == 1)
display_color(0xff,0xff); // change the color of the display to black
Thank you
Heath
