Hello crystalfontz guy,
I'm been wanting to get an LCD display for one of my drive bay. After reading many posts about them, I'm still not sure what components I should get and how to get the LCD works. ^_^
I'm totally blind in electrical and computer stuff. So I prefer not to get involved with soldering and other electrical stuff. I'm thinking in getting your 632 combo set (SKD162632SGLG + bracket + cables). But I still have some questions need to be answered. Here they are:
01. If I get this 632 combo set, do I need to do any soldering or reading some electrical diagrams? I prefer to get everything done since I'm totally clueless about electrical stuff.
02. Am I correct that if I buy the 632 combo set, all I need to do is install the bracket in an empty drive bay, connect the serial cable and run the software to make it work?
03. I understand that this 632 is a serial LCD and needs to be connected to the serial port on the back of my computer. And the easiest way is to get a blank plate from the back dremelled to allow the serial cable to go outside the computer case.
Can I buy this dremelled blank plate from you? If so, how much?
04. Is there any way to make this 632 LCD to show an MP3 title being played? Which software could do that?
05. Can the backlight burn out? If so, what's the expected life of the backlight?
Thanks in advance for your help.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
-mcmlxxv-
![](http://www.crystalfontz.com/backlight/cable_notch.jpg)
-mcmlxxv-
