Seti@Home
Save6
Is there already a possibility that seti@home run with CC ??
if yes.....how should I proceed ?
WinXP Prof
Seti@Home Client ver. 3.07
CC 1.00
Save6
In the settings window (where the timing slider bars are) there will be a box at the bottom to specify seti@home location.
Then in the screen setting window, in the tags listing tree will be a seti@home item with avaliable information to display listed under it. Insert those ~tags~ onto the LCD like normal.
It should then work.
Willem Nijhuis
I have win xp pro and seti command line interface V3.03
Setidriver and setispy running !!
CC is not working white the seti options!! :-(
I set the correct seti location but cant read the .sah files i think..
I reinstall the seti software but no luck !!!
is there solution to the probleem or is this a known bug !!???
Sorry for the poor Engl.
grtz Willem Nijhuis
