I see that others have had problems with SETI@home showing [E16], even if both CrystalControl and the registry has the correct path to the SETI catalogue.
Currently I'm just using the software without a display - but man is the software reason enough to buy an LCD!
The SETI-module does not work - I'm using Windows XP and SETI version 3.0.7. And yes - even if the two required .sah files are present in the catalogue entered in CC/Registry, I still get [E16]
Maybe the file format has changed?
I even tried to copy the SETI catalogue to "C:\SETI" to see if the drive and "@" was a problem, but to no avail.
So is there any news on this?
P.S. I'm using Norwegian XP - but surely, that can't pose a problem?
P.P.S. Three suggestions for future versions of the program:
1) Make it possible to switch the contents of the lines without cutting and pasting.
2) Make it possible to select an inserted string, and change its parameters, without having to look it up again - it's a tedious task.
3) KB/MB per second for NIC I/O would have been nice.
