Set LCD brightness from code?
LamarMarcotte37
So, about two weeks ago I received the Arduino starter kit. Love IT!
Now I came up to the project that displays info on the LCD screen.
For a fututre project I got in mind, I found a setup without using a pot-meter.
Now I'm wondering: is it possible to:
- Shut the LCD off/on from code?
- Set the brightness of the LCD backlight from code?
Any help is greatly appreciated!
thx in advance.
... Now I'm wondering: is it possible to:
Yes. You can use an I/O pin to control a transistor (or FET) that switches power to the display. Since you dont mention what kind of display, I'm assuming a character display. Graphics displays usually have commands that will blank the screen, but the controller is still active (and consuming power).
Yes. You can use another I/O pin set up as a PWM output to control a transistor (or FET) that switches the backlight at various duty cycles.
