Serial 634
PU06
I was wondering if the serial 634 LCD can communicate with a Direct Logic 06 PLC. The PLC can communicate using ASCII transfers, MODBUS RTU, DirectNET or K-sequence.
I do not see any reason it would not be able to. You would want to take a look at the command set in the CFA-634 data sheet. As long as you can generate those sequences, all should be good.
