I have a TM12864A2FFG displayer , with the SED1565 controler ,the problem that i can't obtain the -9.5V when i applied the power supply circuits :
-> Booster circuit control bit :ON
-> Voltage regulator circuit (V regulator circuit) control bit ON >Voltage follower circuit (V/F circuit) control bit ON
but when i applied the Booster circuit control alone i have the -9 V
the Circuit is : 3X charge pump, 4.7uF between CAP2+ and CAP2-, CAP1+ and CAP1-, and Vout connected to CAP3- and through a 4.7uF capacitor to VSS.
for more information of the circuit see this site :http://www.tianma.com/admin/specification/425TM12864A2FFG.pdf
my circuit is when the voltage regulator internal resistor is not used
thanks for help
thanks for help
