Refresh rate calculation for CFAF800480E1-050SN
evrchg
I'm new to displays can someone help me to find the refresh rate for this part using the numbers from datasheet.
I checked through google and most of it mention the refresh rate is 60Hz by default.
the MPU we will be using will have pixel clk frequency of 80Mhz, how does this effect the refresh rate? If i can get a formula for the same it would be helpful.
We will be using Dot-clock for interface with the 80Mhz pixel clk freq. but how does refresh rate of dot-clock vary from refresh rate of MIPI connection. Definitely the MIPI speed is much faster but how does refresh rate relate to clock speeds?
I'm working on choosing the LCD for the project it would be great if someone can respond on this one.
Thank you,
Bhavya
TFT LCD Displays Modules and Development Kits
