The-Kevster
First forum i've found which has anything to do with LCD displays so even tho I don't have a Crystalfontz display i hope you can answer my question.![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I have a Noritake Itron VFD which is LCD compatiable. I've made the software myself using VB using DLportIO. I'm trying to read from the display. I send the read command and the cursor moves to the next character as it should but all i read is whatever the last command was to the parallel port. Am i missing something or is it not possible to read the LCD from the parallel port.
If its not possible could someone explain why?
Thanks alot in advance,
The Kevster
The Kevster
