Question storage electronics with display lcd ips
nonboaran
Does a 3.5" IPS LCD display, when stored for many years without use, easily suffer some degradation and loss of quality in the IPS LCD and LEDs? Loss of brightness, color, contrast, or sharpness?
here my home temperature and humidity varies 33-39C 57-68% without rain
Kody Kou
Yes, some degradation can occur over many years, but how noticeable it is depends on storage conditions and the panel’s construction. For a 3.5" IPS LCD, the risks are moderate, not severe, under the conditions you described.
nonboaran
Given the conditions I mentioned, will my R36S and Powkiddy Q80 handheld consoles—which use 3.5-inch IPS LCD displays—lose significant brightness, color, and contrast, or will the LEDs weaken while the consoles are stored inside their boxes?
Trevin
They should not significantly degrade over time if stored in a box in the conditions you described. Avoid direct sunlight and extreme temperatures. You may also consider putting desiccant packets in the boxes and replacing them periodically to help with the humidity.
nonboaran
without use silica in boxes lcd ips 3,5" lomg term stored loss brightness, loss color, los contrast and leds degrade?
