Question about CFAG12832A-YGH-N
porky2005
I recently purchased the CFAG12832A-YGH-N Graphic LCD with the Sitronix ST7920 Controller. On the spec sheet for the Sitronix contoller it says there are three different types: ST7920-0A, ST7920-0B, and the ST7920-0C. I was wondering what contoller is in the CFAG12832A-YGH-N Graphic LCD. Also I was wondering if anyone had or knew where I could get a character map of all the characters that the controller has.
CF Support2
We have a call in with our factory engineers to verify which character set is standard with the ST7920 on the CFAG12832A-YGH-N.
I have attached the CGROM tables for the three options for your review.
  • st7920-big5.pdf
  • st7920-GB.pdf
  • ST7920-0C-VC11.pdf
porky2005
Thank you! Since the controller can display GB and BIG-5 characters, do you know how to tell the controller that I want to use BIG-5 characters instead of GB. It seems like the default are GB characters. If you have some code that switches between using GB and BIG-5 that would also be a great help.
