Question about backplanes
nzkb
I trying to choose and LCD and drvier combination and was wondering what affect the number of backplanes has on the LCD....
In a nutshell, lower # of backplanes gives:
*higher duty cycle
*lower voltage for a given contrast
*more signals need to be routed to the LCD from the controller
* may be able to use TN LCD fluid
nzkb
Thanks for that!
I have thought of a few specifications that I will try and come up with to help choose and LCD / driver:
- number characters/segments
- supply voltage / current
- overall size
- driver / LCD compatibiliyy
- data lines into driver
Can you think of anyothers I should be considering.
thanks a mil
nzkb
Cool will keep that in mind I think 0-40deg C is what I am looking at so most LCD's should suffice...
Getting back to backplanes so to drive 160 segments on your lcd you would need 44 lines from the micro (assuming 4 backplanes)?
thanks
