Problems with CC2 and HD44780
FiDo
Is anyone succesfully using CC2 with a standard HD44870 display?
I can not seem to get it working with my CFAH2004A-TMI-JP, it should be wired correctley as it works with CFAH_WinTest -program (after installing the Port95NT driver) and also with jaLCD.
How do I set up CC2 to work with this display (if possible)?
FiDo
It actually only display the "test" bars (the two white solid bars).
Seems like the display never really get's initilized.
I found out that when I add a new module (Generic HD44870) I get presented the window with the settings, I choose 0x278 as my port address, I choose 20 columns and 4 rows and I have tried both Slow and Fast for speed. I click add/mod and I get back to the main configuration window.
If I now click configure (module), the window shows 0x278 for address, 20 columns and 12(!) rows, and either Fast/Slow.
If I choose 4 rows again and click add/mod, now the setting sticks.
However I can still only see the test bars (but maybe this have something to do with it).
I have tested my display on two diffrent computers with the same result, I have uninstalled/reinstalled several times.
One computer is running WinXP SP2 and the other one is running MCE2005.
Ok.
Obviously the size selection problem is a bug, ill get that fixed.
Even without that though, you would still see somthing on the LCD.
Can you have a look through the "lcd_hd44780.log" in the cc2-service directory.. or even better, attach it in here?
At a quick guess its a port driver problem (CANIO which should get installed with CC2).
FiDo
Edit This is what it says:
Wed 22 16:55:06 NOTICE log_start: Logging started
Wed 22 16:55:07 NOTICE timer_calibrate: timer ticks/sec: 1837475042.7225
Wed 22 16:55:30 NOTICE log_end: Logging ended
Wed 22 16:55:52 NOTICE log_start: Logging started
Wed 22 16:55:53 NOTICE timer_calibrate: timer ticks/sec: 1837458653.2233
Wed 22 16:55:53 NOTICE ini_check_section: section found: module00
Wed 22 16:55:53 NOTICE ini_read_dword: value found: module00->id = 1604239587
Wed 22 16:55:53 NOTICE ini_read_byte: value found: module00->cols = 20
Wed 22 16:55:53 NOTICE ini_read_byte: value found: module00->rows = 4
Wed 22 16:55:53 NOTICE ini_read_dword: value found: module00->port = 632
Wed 22 16:55:53 NOTICE ini_read_bool: value found: module00->slow = FALSE
Wed 22 16:55:53 ERROR init_lcd: error initilising the lcd module
Wed 22 16:57:00 NOTICE log_end: Logging ended
Wed 22 16:57:11 NOTICE log_start: Logging started
Wed 22 16:57:11 NOTICE timer_calibrate: timer ticks/sec: 1837467493.0447
Wed 22 16:57:11 NOTICE ini_check_section: section found: module00
Wed 22 16:57:11 NOTICE ini_read_dword: value found: module00->id = 1604239587
Wed 22 16:57:11 NOTICE ini_read_byte: value found: module00->cols = 20
Wed 22 16:57:11 NOTICE ini_read_byte: value found: module00->rows = 4
Wed 22 16:57:11 NOTICE ini_read_dword: value found: module00->port = 632
Wed 22 16:57:11 NOTICE ini_read_bool: value found: module00->slow = FALSE
Wed 22 16:57:11 ERROR init_lcd: error initilising the lcd module
Wed 22 17:00:30 NOTICE log_end: Logging ended
Wed 22 17:00:41 NOTICE log_start: Logging started
Wed 22 17:00:41 NOTICE timer_calibrate: timer ticks/sec: 1837457788.5506
Wed 22 17:00:41 NOTICE ini_check_section: section found: module00
Wed 22 17:00:41 NOTICE ini_read_dword: value found: module00->id = 1604239587
Wed 22 17:00:41 NOTICE ini_read_byte: value found: module00->cols = 20
Wed 22 17:00:41 NOTICE ini_read_byte: value found: module00->rows = 4
Wed 22 17:00:41 NOTICE ini_read_dword: value found: module00->port = 888
Wed 22 17:00:41 NOTICE ini_read_bool: value found: module00->slow = FALSE
Wed 22 17:00:41 ERROR init_lcd: error initilising the lcd module
Wed 22 17:01:01 NOTICE log_end: Logging ended
Wed 22 17:01:11 NOTICE log_start: Logging started
Wed 22 17:01:11 NOTICE timer_calibrate: timer ticks/sec: 1837465654.3455
Wed 22 17:01:11 NOTICE ini_check_section: section found: module00
Wed 22 17:01:11 NOTICE ini_read_dword: value found: module00->id = 1604239587
Wed 22 17:01:11 NOTICE ini_read_byte: value found: module00->cols = 20
Wed 22 17:01:11 NOTICE ini_read_byte: value found: module00->rows = 4
Wed 22 17:01:11 NOTICE ini_read_dword: value found: module00->port = 632
Wed 22 17:01:11 NOTICE ini_read_bool: value found: module00->slow = FALSE
Wed 22 17:01:11 ERROR init_lcd: error initilising the lcd module
Wed 22 17:01:30 NOTICE log_end: Logging ended
Wed 22 17:01:40 NOTICE log_start: Logging started
Wed 22 17:01:40 NOTICE timer_calibrate: timer ticks/sec: 1837470805.6547
Wed 22 17:01:41 NOTICE ini_check_section: section found: module00
Wed 22 17:01:41 NOTICE ini_read_dword: value found: module00->id = 1604239587
Wed 22 17:01:41 NOTICE ini_read_byte: value found: module00->cols = 20
Wed 22 17:01:41 NOTICE ini_read_byte: value found: module00->rows = 4
Wed 22 17:01:41 NOTICE ini_read_dword: value found: module00->port = 632
Wed 22 17:01:41 NOTICE ini_read_bool: value found: module00->slow = FALSE
Wed 22 17:01:41 ERROR init_lcd: error initilising the lcd module
Wed 22 17:07:02 NOTICE log_start: Logging started
Wed 22 17:07:02 NOTICE timer_calibrate: timer ticks/sec: 1837469625.6463
Wed 22 17:07:02 NOTICE ini_check_section: section found: module00
Wed 22 17:07:02 NOTICE ini_read_dword: value found: module00->id = 1604239587
Wed 22 17:07:02 NOTICE ini_read_byte: value found: module00->cols = 20
Wed 22 17:07:02 NOTICE ini_read_byte: value found: module00->rows = 4
Wed 22 17:07:02 NOTICE ini_read_dword: value found: module00->port = 632
Wed 22 17:07:02 NOTICE ini_read_bool: value found: module00->slow = FALSE
Wed 22 17:07:05 ERROR init_lcd: error initilising the lcd module
FiDo
Well, I guess this is the problem:
Can I do something about that?
FiDo said:
yes, canio.sys and canio.dll are there.
Ok, thats good, but unfortunatley it doesnt mean CANIO has been properly installed or is working.
I cant think of an easy way to test for this either :(
Do you have CrystalControl1 installed?
FiDo
I have checked the address and also tried diffrent addresses in the BIOS, with the same result.
I do not have CC1 installed, but I can give it a try.
FiDo
with CC1 I get the following message:
Init of "Printer Port 0x278" failed.
The module will be disabled until it is reconfigured.
Any ideas?
XooM
check the address of your printer port, can be done under device manager.... or you can try the other 2 port address provided to u in CC2, most likely it 0x378.
LB11
I am having the exact same problem as him.
I went to uninstall CC2 so I could try CC1 again and it told me that there was a problem and CC@ might already be uninstalled. This is incorrect. But maybe that has something to do with it?
LB11
Just to add CC1 is also telling me printer port failed. I never had this problem before. It is also a brand new install of windows with SP2. I had SP1 before. Could this cause a problem?
FiDo
Thu 30 17:28:50 NOTICE log_start: Logging started
Thu 30 17:28:50 NOTICE timer_calibrate: timer ticks/sec: 1837469002.6804
Thu 30 17:30:32 NOTICE log_end: Logging ended
Thu 30 17:30:43 NOTICE log_start: Logging started
Thu 30 17:30:43 NOTICE timer_calibrate: timer ticks/sec: 1837468973.4376
Thu 30 17:31:56 NOTICE log_start: Logging started
Thu 30 17:31:56 NOTICE timer_calibrate: timer ticks/sec: 1837391442.2985
Thu 30 17:32:45 NOTICE log_end: Logging ended
Thu 30 17:32:55 NOTICE log_start: Logging started
Thu 30 17:32:55 NOTICE timer_calibrate: timer ticks/sec: 1837465651.0574
Thu 30 17:32:55 NOTICE ini_check_section: section found: module00
Thu 30 17:32:55 NOTICE ini_read_dword: value found: module00->id = 1883931748
Thu 30 17:32:55 NOTICE ini_read_byte: value found: module00->cols = 20
Thu 30 17:32:55 NOTICE ini_read_byte: value found: module00->rows = 4
Thu 30 17:32:55 NOTICE ini_read_dword: value found: module00->port = 632
Thu 30 17:32:55 NOTICE ini_read_bool: value found: module00->slow = FALSE
Thu 30 17:32:55 ERROR par_init: could not obtain port permissions using canio
Thu 30 17:32:55 ERROR init_lcd: error initilising the lcd module
This is what I got from the updated dll's.
FiDo
And from the cc2_service.log:
Thu 30 17:28:47 NOTICE log_start: Logging started
Thu 30 17:28:47 NOTICE execute_cc2: Starting ---- CrystalControl2 Service Version 1.00 (build 0042) ----
Thu 30 17:28:47 NOTICE timer_calibrate: timer ticks/sec: 1837460839.2522
Thu 30 17:28:47 NOTICE ini_read_bool: value found: general->windows_start = TRUE
Thu 30 17:28:47 NOTICE execute_cc2: entering main loop
Thu 30 17:28:47 WARNING execute_cc2: signaled to start
Thu 30 17:28:47 NOTICE ini_check_section: section not found: m00
Thu 30 17:28:48 NOTICE load_dlls: DLL_OTHER plugin "cc2_bigchars.dll" loaded
Thu 30 17:28:48 NOTICE load_dlls: DLL_OTHER plugin "cc2_cchar.dll" loaded
Thu 30 17:28:48 NOTICE load_dlls: DLL_OTHER plugin "cc2_email.dll" loaded
Thu 30 17:28:48 NOTICE load_dlls: DLL_OTHER plugin "cc2_foobar2000.dll" loaded
Thu 30 17:28:48 NOTICE load_dlls: DLL_OTHER plugin "cc2_games.dll" loaded
Thu 30 17:28:48 NOTICE load_dlls: DLL_OTHER plugin "cc2_hbar.dll" loaded
Thu 30 17:28:48 NOTICE load_dlls: DLL_OTHER plugin "cc2_histogram.dll" loaded
Thu 30 17:28:48 NOTICE load_dlls: DLL_OTHER plugin "cc2_keyboard.dll" loaded
Thu 30 17:28:49 NOTICE load_dlls: DLL_OTHER plugin "cc2_mbm.dll" loaded
Thu 30 17:28:49 NOTICE load_dlls: DLL_OTHER plugin "cc2_perfmon.dll" loaded
Thu 30 17:28:49 NOTICE load_dlls: DLL_OTHER plugin "cc2_process.dll" loaded
Thu 30 17:28:49 NOTICE load_dlls: DLL_OTHER plugin "cc2_rivatuner.dll" loaded
Thu 30 17:28:49 NOTICE load_dlls: DLL_OTHER plugin "cc2_showgif.dll" loaded
Thu 30 17:28:49 NOTICE load_dlls: DLL_OTHER plugin "cc2_speedfan.dll" loaded
Thu 30 17:28:49 NOTICE load_dlls: DLL_OTHER plugin "cc2_sysinfo.dll" loaded
Thu 30 17:28:49 NOTICE load_dlls: DLL_OTHER plugin "cc2_textfile.dll" loaded
Thu 30 17:28:50 NOTICE load_dlls: DLL_OTHER plugin "cc2_timedate.dll" loaded
Thu 30 17:28:50 NOTICE load_dlls: DLL_OTHER plugin "cc2_winamp2.dll" loaded
Thu 30 17:28:50 NOTICE load_dlls: DLL_OTHER plugin "cc2_winamp2_vis.dll" loaded
Thu 30 17:28:50 NOTICE load_dlls: DLL_LCD plugin "lcd_631.dll" loaded
Thu 30 17:28:50 NOTICE load_dlls: DLL_OTHER plugin "lcd_631.dll" loaded
Thu 30 17:28:50 NOTICE load_dlls: DLL_LCD plugin "lcd_632.dll" loaded
Thu 30 17:28:50 NOTICE load_dlls: DLL_LCD plugin "lcd_633.dll" loaded
Thu 30 17:28:50 NOTICE load_dlls: DLL_OTHER plugin "lcd_633.dll" loaded
Thu 30 17:28:50 NOTICE load_dlls: DLL_LCD plugin "lcd_634.dll" loaded
Thu 30 17:28:50 NOTICE load_dlls: DLL_LCD plugin "lcd_hd44780.dll" loaded
Thu 30 17:28:50 NOTICE load_dlls: DLL_LCD plugin "lcd_hd44780d.dll" loaded
Thu 30 17:28:50 WARNING execute_cc2: is now running
Thu 30 17:30:28 WARNING execute_cc2: signaled to stop
Thu 30 17:30:28 WARNING execute_cc2: unload dlls
Thu 30 17:30:28 NOTICE unload_dlls: unloading plugin "cc2_bigchars.dll"
Thu 30 17:30:28 NOTICE unload_dlls: unloading plugin "cc2_cchar.dll"
Thu 30 17:30:28 NOTICE unload_dlls: unloading plugin "cc2_email.dll"
Thu 30 17:30:28 NOTICE unload_dlls: unloading plugin "cc2_foobar2000.dll"
Thu 30 17:30:29 NOTICE unload_dlls: unloading plugin "cc2_games.dll"
Thu 30 17:30:29 NOTICE unload_dlls: unloading plugin "cc2_hbar.dll"
Thu 30 17:30:29 NOTICE unload_dlls: unloading plugin "cc2_histogram.dll"
Thu 30 17:30:29 NOTICE unload_dlls: unloading plugin "cc2_keyboard.dll"
Thu 30 17:30:29 NOTICE unload_dlls: unloading plugin "cc2_mbm.dll"
Thu 30 17:30:30 NOTICE unload_dlls: unloading plugin "cc2_perfmon.dll"
Thu 30 17:30:30 NOTICE unload_dlls: unloading plugin "cc2_process.dll"
Thu 30 17:30:30 NOTICE unload_dlls: unloading plugin "cc2_rivatuner.dll"
Thu 30 17:30:30 NOTICE unload_dlls: unloading plugin "cc2_showgif.dll"
Thu 30 17:30:31 NOTICE unload_dlls: unloading plugin "cc2_speedfan.dll"
Thu 30 17:30:31 NOTICE unload_dlls: unloading plugin "cc2_sysinfo.dll"
Thu 30 17:30:31 NOTICE unload_dlls: unloading plugin "cc2_textfile.dll"
Thu 30 17:30:31 NOTICE unload_dlls: unloading plugin "cc2_timedate.dll"
Thu 30 17:30:32 NOTICE unload_dlls: unloading plugin "cc2_winamp2.dll"
Thu 30 17:30:32 NOTICE unload_dlls: unloading plugin "cc2_winamp2_vis.dll"
Thu 30 17:30:32 NOTICE unload_dlls: unloading plugin "lcd_631.dll"
Thu 30 17:30:32 NOTICE unload_dlls: unloading plugin "lcd_632.dll"
Thu 30 17:30:32 NOTICE unload_dlls: unloading plugin "lcd_633.dll"
Thu 30 17:30:32 NOTICE unload_dlls: unloading plugin "lcd_634.dll"
Thu 30 17:30:32 NOTICE unload_dlls: unloading plugin "lcd_hd44780.dll"
Thu 30 17:30:32 NOTICE unload_dlls: unloading plugin "lcd_hd44780d.dll"
Thu 30 17:30:32 WARNING execute_cc2: free dlls
Thu 30 17:30:32 WARNING execute_cc2: free set
Thu 30 17:30:32 WARNING execute_cc2: has stopped
Thu 30 17:30:40 WARNING execute_cc2: signaled to start
Thu 30 17:30:40 NOTICE ini_read_bool: value found: general->windows_start = TRUE
Thu 30 17:30:40 NOTICE ini_check_section: section not found: m00
Thu 30 17:30:40 NOTICE load_dlls: DLL_OTHER plugin "cc2_bigchars.dll" loaded
Thu 30 17:30:41 NOTICE load_dlls: DLL_OTHER plugin "cc2_cchar.dll" loaded
Thu 30 17:30:41 NOTICE load_dlls: DLL_OTHER plugin "cc2_email.dll" loaded
Thu 30 17:30:41 NOTICE load_dlls: DLL_OTHER plugin "cc2_foobar2000.dll" loaded
Thu 30 17:30:41 NOTICE load_dlls: DLL_OTHER plugin "cc2_games.dll" loaded
Thu 30 17:30:41 NOTICE load_dlls: DLL_OTHER plugin "cc2_hbar.dll" loaded
Thu 30 17:30:41 NOTICE load_dlls: DLL_OTHER plugin "cc2_histogram.dll" loaded
Thu 30 17:30:41 NOTICE load_dlls: DLL_OTHER plugin "cc2_keyboard.dll" loaded
Thu 30 17:30:41 NOTICE load_dlls: DLL_OTHER plugin "cc2_mbm.dll" loaded
Thu 30 17:30:41 NOTICE load_dlls: DLL_OTHER plugin "cc2_perfmon.dll" loaded
Thu 30 17:30:41 NOTICE load_dlls: DLL_OTHER plugin "cc2_process.dll" loaded
Thu 30 17:30:41 NOTICE load_dlls: DLL_OTHER plugin "cc2_rivatuner.dll" loaded
Thu 30 17:30:42 NOTICE load_dlls: DLL_OTHER plugin "cc2_showgif.dll" loaded
Thu 30 17:30:42 NOTICE load_dlls: DLL_OTHER plugin "cc2_speedfan.dll" loaded
Thu 30 17:30:42 NOTICE load_dlls: DLL_OTHER plugin "cc2_sysinfo.dll" loaded
Thu 30 17:30:42 NOTICE load_dlls: DLL_OTHER plugin "cc2_textfile.dll" loaded
Thu 30 17:30:42 NOTICE load_dlls: DLL_OTHER plugin "cc2_timedate.dll" loaded
Thu 30 17:30:42 NOTICE load_dlls: DLL_OTHER plugin "cc2_winamp2.dll" loaded
Thu 30 17:30:42 NOTICE load_dlls: DLL_OTHER plugin "cc2_winamp2_vis.dll" loaded
Thu 30 17:30:42 NOTICE load_dlls: DLL_LCD plugin "lcd_631.dll" loaded
Thu 30 17:30:42 NOTICE load_dlls: DLL_OTHER plugin "lcd_631.dll" loaded
Thu 30 17:30:43 NOTICE load_dlls: DLL_LCD plugin "lcd_632.dll" loaded
Thu 30 17:30:43 NOTICE load_dlls: DLL_LCD plugin "lcd_633.dll" loaded
Thu 30 17:30:43 NOTICE load_dlls: DLL_OTHER plugin "lcd_633.dll" loaded
Thu 30 17:30:43 NOTICE load_dlls: DLL_LCD plugin "lcd_634.dll" loaded
Thu 30 17:30:43 NOTICE load_dlls: DLL_LCD plugin "lcd_hd44780.dll" loaded
Thu 30 17:30:43 NOTICE load_dlls: DLL_LCD plugin "lcd_hd44780d.dll" loaded
Thu 30 17:30:43 WARNING execute_cc2: is now running
Thu 30 17:30:58 WARNING execute_cc2: signaled to die
Thu 30 17:30:58 WARNING execute_cc2: unload dlls
Thu 30 17:30:58 NOTICE unload_dlls: unloading plugin "cc2_bigchars.dll"
Thu 30 17:30:58 NOTICE unload_dlls: unloading plugin "cc2_cchar.dll"
Thu 30 17:30:58 NOTICE unload_dlls: unloading plugin "cc2_email.dll"
Thu 30 17:30:58 NOTICE unload_dlls: unloading plugin "cc2_foobar2000.dll"
Thu 30 17:30:58 NOTICE unload_dlls: unloading plugin "cc2_games.dll"
Thu 30 17:30:59 NOTICE unload_dlls: unloading plugin "cc2_hbar.dll"
Thu 30 17:30:59 NOTICE unload_dlls: unloading plugin "cc2_histogram.dll"
Thu 30 17:30:59 NOTICE unload_dlls: unloading plugin "cc2_keyboard.dll"
Thu 30 17:30:59 NOTICE unload_dlls: unloading plugin "cc2_mbm.dll"
Thu 30 17:30:59 NOTICE unload_dlls: unloading plugin "cc2_perfmon.dll"
Thu 30 17:30:59 NOTICE unload_dlls: unloading plugin "cc2_process.dll"
Thu 30 17:30:59 NOTICE unload_dlls: unloading plugin "cc2_rivatuner.dll"
Thu 30 17:31:00 NOTICE unload_dlls: unloading plugin "cc2_showgif.dll"
Thu 30 17:31:01 NOTICE unload_dlls: unloading plugin "cc2_speedfan.dll"
Thu 30 17:31:01 NOTICE unload_dlls: unloading plugin "cc2_sysinfo.dll"
Thu 30 17:31:01 NOTICE unload_dlls: unloading plugin "cc2_textfile.dll"
Thu 30 17:31:01 NOTICE unload_dlls: unloading plugin "cc2_timedate.dll"
Thu 30 17:31:01 NOTICE unload_dlls: unloading plugin "cc2_winamp2.dll"
Thu 30 17:31:01 NOTICE unload_dlls: unloading plugin "cc2_winamp2_vis.dll"
Thu 30 17:31:53 NOTICE log_start: Logging started
Thu 30 17:31:53 NOTICE execute_cc2: Starting ---- CrystalControl2 Service Version 1.00 (build 0042) ----
Thu 30 17:31:53 NOTICE timer_calibrate: timer ticks/sec: 1837457825.5652
Thu 30 17:31:53 NOTICE ini_read_bool: value found: general->windows_start = TRUE
Thu 30 17:31:53 NOTICE execute_cc2: entering main loop
Thu 30 17:31:53 WARNING execute_cc2: signaled to start
Thu 30 17:31:53 NOTICE ini_check_section: section not found: m00
Thu 30 17:31:54 NOTICE load_dlls: DLL_OTHER plugin "cc2_bigchars.dll" loaded
Thu 30 17:31:54 NOTICE load_dlls: DLL_OTHER plugin "cc2_cchar.dll" loaded
Thu 30 17:31:54 NOTICE load_dlls: DLL_OTHER plugin "cc2_email.dll" loaded
Thu 30 17:31:54 NOTICE load_dlls: DLL_OTHER plugin "cc2_foobar2000.dll" loaded
Thu 30 17:31:54 NOTICE load_dlls: DLL_OTHER plugin "cc2_games.dll" loaded
Thu 30 17:31:54 NOTICE load_dlls: DLL_OTHER plugin "cc2_hbar.dll" loaded
Thu 30 17:31:54 NOTICE load_dlls: DLL_OTHER plugin "cc2_histogram.dll" loaded
Thu 30 17:31:54 NOTICE load_dlls: DLL_OTHER plugin "cc2_keyboard.dll" loaded
Thu 30 17:31:54 NOTICE load_dlls: DLL_OTHER plugin "cc2_mbm.dll" loaded
Thu 30 17:31:55 NOTICE load_dlls: DLL_OTHER plugin "cc2_perfmon.dll" loaded
Thu 30 17:31:55 NOTICE load_dlls: DLL_OTHER plugin "cc2_process.dll" loaded
Thu 30 17:31:55 NOTICE load_dlls: DLL_OTHER plugin "cc2_rivatuner.dll" loaded
Thu 30 17:31:55 NOTICE load_dlls: DLL_OTHER plugin "cc2_showgif.dll" loaded
Thu 30 17:31:55 NOTICE load_dlls: DLL_OTHER plugin "cc2_speedfan.dll" loaded
Thu 30 17:31:55 NOTICE load_dlls: DLL_OTHER plugin "cc2_sysinfo.dll" loaded
Thu 30 17:31:55 NOTICE load_dlls: DLL_OTHER plugin "cc2_textfile.dll" loaded
Thu 30 17:31:55 NOTICE load_dlls: DLL_OTHER plugin "cc2_timedate.dll" loaded
Thu 30 17:31:56 NOTICE load_dlls: DLL_OTHER plugin "cc2_winamp2.dll" loaded
Thu 30 17:31:56 NOTICE load_dlls: DLL_OTHER plugin "cc2_winamp2_vis.dll" loaded
Thu 30 17:31:56 NOTICE load_dlls: DLL_LCD plugin "lcd_631.dll" loaded
Thu 30 17:31:56 NOTICE load_dlls: DLL_OTHER plugin "lcd_631.dll" loaded
Thu 30 17:31:56 NOTICE load_dlls: DLL_LCD plugin "lcd_632.dll" loaded
Thu 30 17:31:56 NOTICE load_dlls: DLL_LCD plugin "lcd_633.dll" loaded
Thu 30 17:31:56 NOTICE load_dlls: DLL_OTHER plugin "lcd_633.dll" loaded
Thu 30 17:31:56 NOTICE load_dlls: DLL_LCD plugin "lcd_634.dll" loaded
Thu 30 17:31:56 NOTICE load_dlls: DLL_LCD plugin "lcd_hd44780.dll" loaded
Thu 30 17:31:56 NOTICE load_dlls: DLL_LCD plugin "lcd_hd44780d.dll" loaded
Thu 30 17:31:56 WARNING execute_cc2: is now running
Thu 30 17:32:41 WARNING execute_cc2: signaled to restart
Thu 30 17:32:41 WARNING execute_cc2: unload dlls
Thu 30 17:32:41 NOTICE unload_dlls: unloading plugin "cc2_bigchars.dll"
Thu 30 17:32:41 NOTICE unload_dlls: unloading plugin "cc2_cchar.dll"
Thu 30 17:32:41 NOTICE unload_dlls: unloading plugin "cc2_email.dll"
Thu 30 17:32:41 NOTICE unload_dlls: unloading plugin "cc2_foobar2000.dll"
Thu 30 17:32:41 NOTICE unload_dlls: unloading plugin "cc2_games.dll"
Thu 30 17:32:42 NOTICE unload_dlls: unloading plugin "cc2_hbar.dll"
Thu 30 17:32:42 NOTICE unload_dlls: unloading plugin "cc2_histogram.dll"
Thu 30 17:32:42 NOTICE unload_dlls: unloading plugin "cc2_keyboard.dll"
Thu 30 17:32:42 NOTICE unload_dlls: unloading plugin "cc2_mbm.dll"
Thu 30 17:32:43 NOTICE unload_dlls: unloading plugin "cc2_perfmon.dll"
Thu 30 17:32:43 NOTICE unload_dlls: unloading plugin "cc2_process.dll"
Thu 30 17:32:43 NOTICE unload_dlls: unloading plugin "cc2_rivatuner.dll"
Thu 30 17:32:43 NOTICE unload_dlls: unloading plugin "cc2_showgif.dll"
Thu 30 17:32:44 NOTICE unload_dlls: unloading plugin "cc2_speedfan.dll"
Thu 30 17:32:44 NOTICE unload_dlls: unloading plugin "cc2_sysinfo.dll"
Thu 30 17:32:44 NOTICE unload_dlls: unloading plugin "cc2_textfile.dll"
Thu 30 17:32:44 NOTICE unload_dlls: unloading plugin "cc2_timedate.dll"
Thu 30 17:32:44 NOTICE unload_dlls: unloading plugin "cc2_winamp2.dll"
Thu 30 17:32:44 NOTICE unload_dlls: unloading plugin "cc2_winamp2_vis.dll"
Thu 30 17:32:45 NOTICE unload_dlls: unloading plugin "lcd_631.dll"
Thu 30 17:32:45 NOTICE unload_dlls: unloading plugin "lcd_632.dll"
Thu 30 17:32:45 NOTICE unload_dlls: unloading plugin "lcd_633.dll"
Thu 30 17:32:45 NOTICE unload_dlls: unloading plugin "lcd_634.dll"
Thu 30 17:32:45 NOTICE unload_dlls: unloading plugin "lcd_hd44780.dll"
Thu 30 17:32:45 NOTICE unload_dlls: unloading plugin "lcd_hd44780d.dll"
Thu 30 17:32:45 WARNING execute_cc2: free dlls
Thu 30 17:32:45 WARNING execute_cc2: free set
Thu 30 17:32:53 NOTICE ini_read_bool: value found: general->windows_start = TRUE
Thu 30 17:32:53 NOTICE ini_check_section: section found: m00
Thu 30 17:32:53 NOTICE ini_read_string: value found: m00->module_name = "HD44780"
Thu 30 17:32:53 NOTICE ini_read_dword: value found: m00->id = 1883931748
Thu 30 17:32:53 NOTICE ini_read_byte: value found: m00->options = 0
Thu 30 17:32:53 NOTICE ini_read_dword: value found: m00->screen_sel = 0
Thu 30 17:32:53 NOTICE ini_read_bool: value found: m00->alt_enabled = FALSE
Thu 30 17:32:53 NOTICE ini_read_byte: value found: m00->brightness = 50
Thu 30 17:32:53 NOTICE ini_read_byte: value found: m00->contrast = 50
Thu 30 17:32:53 NOTICE ini_check_section: section not found: m00-event00
Thu 30 17:32:53 NOTICE ini_check_section: section found: m00-s00
Thu 30 17:32:53 NOTICE ini_read_string: value found: m00-s00->screen_name = "Date/Time & Uptime"
Thu 30 17:32:53 NOTICE ini_read_byte: value found: m00-s00->options = 0
Thu 30 17:32:53 NOTICE ini_read_word: value found: m00-s00->alt_delay = 5000
Thu 30 17:32:53 NOTICE ini_check_section: section not found: m00-s00-event00
Thu 30 17:32:53 NOTICE ini_read_byte: value found: m00-s00-r00->options = 5
Thu 30 17:32:53 NOTICE ini_read_dword: value found: m00-s00-r00->scroll_speed = 250
Thu 30 17:32:53 NOTICE ini_check_section: section found: m00-s00-r00-i00
Thu 30 17:32:53 NOTICE ini_read_word: value found: m00-s00-r00-i00->length = 0
Thu 30 17:32:53 NOTICE ini_read_byte: value found: m00-s00-r00-i00->options = 0
Thu 30 17:32:53 NOTICE ini_check_key: key found: m00-s00-r00-i00->id
Thu 30 17:32:53 NOTICE ini_read_dword: value found: m00-s00-r00-i00->id = 1731734103
Thu 30 17:32:53 NOTICE ini_check_section: section not found: m00-s00-r00-i01
Thu 30 17:32:53 NOTICE ini_read_byte: value found: m00-s00-r01->options = 5
Thu 30 17:32:53 NOTICE ini_read_dword: value found: m00-s00-r01->scroll_speed = 250
Thu 30 17:32:53 NOTICE ini_check_section: section found: m00-s00-r01-i00
Thu 30 17:32:53 NOTICE ini_read_word: value found: m00-s00-r01-i00->length = 0
Thu 30 17:32:53 NOTICE ini_read_byte: value found: m00-s00-r01-i00->options = 0
Thu 30 17:32:53 NOTICE ini_check_key: key found: m00-s00-r01-i00->id
Thu 30 17:32:53 NOTICE ini_read_dword: value found: m00-s00-r01-i00->id = 1112400219
Thu 30 17:32:53 NOTICE ini_check_section: section not found: m00-s00-r01-i01
Thu 30 17:32:53 NOTICE ini_read_byte: value found: m00-s00-r02->options = 5
Thu 30 17:32:53 NOTICE ini_read_dword: value found: m00-s00-r02->scroll_speed = 250
Thu 30 17:32:53 NOTICE ini_check_section: section not found: m00-s00-r02-i00
Thu 30 17:32:53 NOTICE ini_read_byte: value found: m00-s00-r03->options = 5
Thu 30 17:32:53 NOTICE ini_read_dword: value found: m00-s00-r03->scroll_speed = 250
Thu 30 17:32:53 NOTICE ini_check_section: section found: m00-s00-r03-i00
Thu 30 17:32:53 NOTICE ini_read_word: value found: m00-s00-r03-i00->length = 0
Thu 30 17:32:53 NOTICE ini_read_byte: value found: m00-s00-r03-i00->options = 0
Thu 30 17:32:53 NOTICE ini_check_section: section/key not found: m00-s00-r03-i00->id
Thu 30 17:32:53 NOTICE ini_check_key: key found: m00-s00-r03-i00->string
Thu 30 17:32:53 NOTICE ini_read_string: value found: m00-s00-r03-i00->string = "Uptime: "
Thu 30 17:32:53 NOTICE ini_check_section: section found: m00-s00-r03-i01
Thu 30 17:32:53 NOTICE ini_read_word: value found: m00-s00-r03-i01->length = 0
Thu 30 17:32:53 NOTICE ini_read_byte: value found: m00-s00-r03-i01->options = 0
Thu 30 17:32:53 NOTICE ini_check_key: key found: m00-s00-r03-i01->id
Thu 30 17:32:53 NOTICE ini_read_dword: value found: m00-s00-r03-i01->id = 3451264379
Thu 30 17:32:53 NOTICE ini_check_section: section not found: m00-s00-r03-i02
Thu 30 17:32:53 NOTICE ini_check_section: section not found: m00-s01
Thu 30 17:32:53 NOTICE ini_check_section: section not found: m01
Thu 30 17:32:53 NOTICE load_dlls: DLL_OTHER plugin "cc2_bigchars.dll" loaded
Thu 30 17:32:53 NOTICE load_dlls: DLL_OTHER plugin "cc2_cchar.dll" loaded
Thu 30 17:32:53 NOTICE load_dlls: DLL_OTHER plugin "cc2_email.dll" loaded
Thu 30 17:32:53 NOTICE load_dlls: DLL_OTHER plugin "cc2_foobar2000.dll" loaded
Thu 30 17:32:53 NOTICE load_dlls: DLL_OTHER plugin "cc2_games.dll" loaded
Thu 30 17:32:53 NOTICE load_dlls: DLL_OTHER plugin "cc2_hbar.dll" loaded
Thu 30 17:32:53 NOTICE load_dlls: DLL_OTHER plugin "cc2_histogram.dll" loaded
Thu 30 17:32:54 NOTICE load_dlls: DLL_OTHER plugin "cc2_keyboard.dll" loaded
Thu 30 17:32:54 NOTICE load_dlls: DLL_OTHER plugin "cc2_mbm.dll" loaded
Thu 30 17:32:54 NOTICE load_dlls: DLL_OTHER plugin "cc2_perfmon.dll" loaded
Thu 30 17:32:54 NOTICE load_dlls: DLL_OTHER plugin "cc2_process.dll" loaded
Thu 30 17:32:54 NOTICE load_dlls: DLL_OTHER plugin "cc2_rivatuner.dll" loaded
Thu 30 17:32:54 NOTICE load_dlls: DLL_OTHER plugin "cc2_showgif.dll" loaded
Thu 30 17:32:54 NOTICE load_dlls: DLL_OTHER plugin "cc2_speedfan.dll" loaded
Thu 30 17:32:54 NOTICE load_dlls: DLL_OTHER plugin "cc2_sysinfo.dll" loaded
Thu 30 17:32:55 NOTICE load_dlls: DLL_OTHER plugin "cc2_textfile.dll" loaded
Thu 30 17:32:55 NOTICE load_dlls: DLL_OTHER plugin "cc2_timedate.dll" loaded
Thu 30 17:32:55 NOTICE load_dlls: DLL_OTHER plugin "cc2_winamp2.dll" loaded
Thu 30 17:32:55 NOTICE load_dlls: DLL_OTHER plugin "cc2_winamp2_vis.dll" loaded
Thu 30 17:32:55 NOTICE load_dlls: DLL_LCD plugin "lcd_631.dll" loaded
Thu 30 17:32:55 NOTICE load_dlls: DLL_OTHER plugin "lcd_631.dll" loaded
Thu 30 17:32:55 NOTICE load_dlls: DLL_LCD plugin "lcd_632.dll" loaded
Thu 30 17:32:55 NOTICE load_dlls: DLL_LCD plugin "lcd_633.dll" loaded
Thu 30 17:32:55 NOTICE load_dlls: DLL_OTHER plugin "lcd_633.dll" loaded
Thu 30 17:32:55 NOTICE load_dlls: DLL_LCD plugin "lcd_634.dll" loaded
Thu 30 17:32:55 NOTICE load_dlls: DLL_LCD plugin "lcd_hd44780.dll" loaded
Thu 30 17:32:55 NOTICE load_dlls: DLL_LCD plugin "lcd_hd44780d.dll" loaded
Thu 30 17:32:55 ERROR init_modules: error initilising module (ID = 1883931748)
Thu 30 17:32:55 WARNING execute_cc2: has restarted
LB11
I think the problem is SP2 for windows. I was looking around the net and there is threads hear and there with people complaining that when they installed SP2 there parallel port wont work. Im going to try my brothers SP2 install now.
