I want to use the CFA633 in my living room, to control a PC located in my garage. I have a USB1.1 extension; one end is connected to the PC in the garage, the other to a 4-port hub in the living room.
But if I'm not mistaken, this CFA-633 will only work if a 3.5" floppy power connector is plugged into it. I've been playing around with it this week-end, and the data-sheet is not 100% clear to me, but it seems the CFA-633 needs the 5 VDC on PWR (J1?) to get power to the LCD screen and backlight. And the USB to RS-232 bridge does not seem to be supplying any power (RS-232 is a control-only interface, no pins for power supply, right?).
Does this mean the 5V line from the USB plug is not being used for anything on the CFA-633? Could I solder a line from USB's 5V line and GND to the PWR's 5V line and GND? I know USB doesn't supply many amps (0.5 is max I think), but I'm guessing its enough to power the LCD screen and backlight.
I'm surprised this question hasn't been asked before (how to power 633 with just one USB cord), but I searched the forums and couldn't find any topic related to it. Is the issue amps?
Thanks for the help, in advance!
