power supply CFAH with atx cable
jesz
Can I use this cable :WR232Y02 to supply a standard LCD CFAH(connect pin V+ and V- with red and black cable)?
Else, how to....?
We do not recommend the parallel modules (such as the one you are interested in) for end-user PC applications. These modules require more extensive wiring knowledge and the proper tools. These modules are primarily intended for OEM (manufacturer) use, and as such, we do not carry any cables, brackets, or serial adapters for these modules.
We do not offer end-user tech support on the CFAH* or CFAG* series LCDs in PC applications. We will not accept returns on CFAH* or CFAG* LCDs damaged in an attempt to connect them to a PC.
The serial modules and kits (634, 633, 632 models and kits: http://www.crystalfontz.com/products/select_kit.html) are best suited for PC applications.
Please see this forum thread for our PCuser LCD recommendations:
https://forum.crystalfontz.com/showthread.php?s=&postid=1922
Good wiring guides for HD44780 compatible LCD's can be found:
http://www.myrolypoly.com/lcd_project/lcd_project.html
http://www.icehw.net/article.asp?id=104
http://www.geocities.com/ResearchTriangle/1495/ee_lcd.html
http://www.overclockers.com.au/techstuff/a_diy_lcd/
http://www.hardforum.com/showthread.php?threadid=248302
You can also go to http://forums.bit-tech.net/showthread.php?threadid=5582 and search for "assuming alphanumeric" and you will find a short Q/A post on parallel displays.
Back
