power supply CFAH with atx cable
jesz
Can I use this cable :WR232Y02 to supply a standard LCD CFAH(connect pin V+ and V- with red and black cable)?
Else, how to....?
We do not offer end-user tech support on the CFAH* or CFAG* series LCDs in PC applications. We will not accept returns on CFAH* or CFAG* LCDs damaged in an attempt to connect them to a PC.
The serial modules and kits (634, 633, 632 models and kits: http://www.crystalfontz.com/products/select_kit.html) are best suited for PC applications.
Please see this forum thread for our PCuser LCD recommendations:
https://forum.crystalfontz.com/showthread.php?s=&postid=1922
Good wiring guides for HD44780 compatible LCD's can be found:
http://www.myrolypoly.com/lcd_project/lcd_project.html
http://www.icehw.net/article.asp?id=104
http://www.geocities.com/ResearchTriangle/1495/ee_lcd.html
http://www.hardforum.com/showthread.php?threadid=248302
You can also go to http://forums.bit-tech.net/showthread.php?threadid=5582 and search for "assuming alphanumeric" and you will find a short Q/A post on parallel displays.
