Power issues while having SCAB connected
antand
Hi! Im having some problem with Chrystalfontz SCAB card.
Nothing is powered up in my computer as long as I have the power connected to the SCAB card. When I unplug only the power connector from SCAB, everything is fine.
I can also get power when the SCAB is powered if I, after I put the 230v chord in the PSU, just unplug and put back the power to the motherboard….
Setup:
tried different PSU:s: Corsair HX1050, FSP 750W
motherboard: gigabyte p67a-ud7-b3
SCAB and CFA635
Thankful for any help!
That is a strange problem.
Try unplugging everything from the SCAB except for the floppy-drive power connector and the SCAB to CFA635 cable.
What happens then?
antand
What happens then?
Like this? Still nothing..
CF Support2
it goes to the CFA635
So you are pulling for the 7 pin header (J8) on the SCAB back to the CFA635?
That header is an extension of the GPIO lines from the CFA635 (via H1). The +5v, +12v, and ground lines are input to the SCAB. The module is should only be connected to the SCAB via the 16 pin cable (WREXTY15 is what you are using) - this connects power (+5v), GPIO, Fan control and temp sensors. I'm wondering if something got borked along the way.
antand
Im sorry but that cable was going to a ledboard and not to the cfa635. The only cable going to cfa635 from the scab is the silver cable.
CF Support2
My apologies for the delay in getting back to you.
With the SCAB connected to the PSU - you get no power on the system at all, correct?
This condition happens when the CFA635 is connected or is not connected -- I am wondering if there is a short somewhere. Can I have you un-mount the SCAB from the chassis and see if the problem continues?
antand
OK, so i got a new SCAB and still the same problem. lifted the card up from its place and plugged in the 230v power chord but still nothing.
