power consumption for black & white?
willwarner
Sorry for the newbie question, but I can't find the info online. Does an LCD use more power showing a white screen than a black one? Or does it just leave the bulb on all the time, and which pixels are open or closed doesn't affect power use?
Also, I thought that an incandescent bulb could burn at varying power and brightness, but a flourescent bulb had to just be on or off. Is that true? If so, why does an LCD use more power at higher brightness?
Thanks!
The LCD uses the same amount of power showing black or white. The LC material acts as a "shutter", blocking the light on dark pixels.
The CCFL bulbs are not "easy" to dim (the way an incandescent bulb is), but they can be dimmed with specially designed inverters.
