I've been trying to get an optrex F-51852 display running for a while now with not much luck. I'm using the Freescale DEMOQE board with the 8-bit micro, 9S08qe128. This board operates at around 3.1 volts, and i have a breakout board connected to the demo board so that i can interface with all of the data and control lines of the lcd. This LCD has a NJU6676 controller inside.
I have not been successful at getting anything to work at all with this display. I have traced out all my connections to make sure that the I/O pins are working right and connected to the right pin (using parallel mode, 68 type interface). I am wondering if these displays can even work at this voltage??? The datasheets says yes, but i'm wondering if that is just a dumb spec and not practical.
I would appreciate any advice.
Thank you,
Aaron
Thank you,
Aaron
