duroncrush
I've tried every piece of software I can find the only one that does anything is 633_WinTest_0_1.zip I can see the temp read outs, controll the fans and adjust the contrst and brightness. the dispaly shows blocks or version and firmware info but I can't get it to show anything usefull. If I click the button that says F=0, int temps the dispaly changes to
633_wintest
Module Reset
When I try crystalcontrol 0.92 build103 all I get is a display of blocks the virtual LCD will show the correct data but just blocks on the LCD. I can't change the contrast or brightness.
What am I doing wrong? I want to use MBM5 to monitor the temp and fan speeds how do I get it to do that with the 633?
Guess I should add I'm running windows 2000 Pro
633_wintest
Module Reset
