Gooserider
I am looking at getting a fan controller / system status monitor for the Linux box that I'm building. It will be a liquid cooled system built into a server-cube type case with four 120mm fans, two on the intake, and two on the exhaust. As a firm believer in the idea that PC's should be silent or close to it, I want to have temperature sensitive variable speed control on the fans so that I can run them at the lowest possible speed providing acceptable temperatures at any instant. I find lots of 'Baybus' style manually adjustable controllers, which IMHO miss the point, a computer should be able to handle such things automatically, not require extra work from the user!
Ideally, I would like the controller to be able to monitor other system health type functions (Resevoir coolant level, coolant flow, fan failure, leak detection, etc.) and be able to shut the system down if needed. It should also run on it's own microprocessor so that it does not depend on, or steal processing power from, the main O/S running on the motherboard. I feel this would make the controller more efficient and reliable, as well as giving greater independence as to what is running on the main board. (I sometimes play with other operating systems) Other than initial configuration, and possibly optional reporting, I'd like the controller to operate completely seperately from the main system.
The users Dutch2 and FanControl over on Silent PC Review have home built designs that are very close to what I want, but FanControl's unit doesn't support enough fans or have enough software support. Dutch2 left the board abruptly, so his unit isn't available but the thread describing it is excellent. Innovatek has a unit called the 'Fan-O-Matic' which I think would do what I want except that it isn't available in the US, and does not have Linux compatible configuration software.
The 633 comes very close to what I'm looking for, in terms of functionality, but it has some limitations, the biggest being that it relies excessively on software running under the main O/S. However this might be tolerable given the 633's watchdog safety function.
What I would like to see is a CF unit with the following functionality...
1. A larger display? I'd like to see the largest display that can be fit into a standard 5.25" half height drive bay. This is relatively minor, I could live with a 633 size display, but bigger is better...
2. A more robust on board Microprocessor with sufficient memory (Flash?) to allow a configured unit to remember it's programming and run independently of the motherboard.
3. Configuration software that runs as O/S independently as possible (Java based?) at the very least it must run under Linux and that other insecure, overpriced O/S.
4. Either loose the keypad, or make it do something useful. (BTW, most cases already have power and reset buttons, so duplicating them on the keypad is NOT a useful function IMHO) Possible useful things would be to change the contrast or step through a multi-line display output.
5. Possibly add support for more fans and / or some additional generic user configurable input / output pins.
6. Keep the DOW sensors, it is one of the better things about the 633.
Based on what Dutch2 and Fancontrol were talking about offering on their controllers (purchasing single unit quantity parts) I'm sure that CF could easily offer something at around $100, which is a price I would gladly pay for such a unit.
ART
ART
