Help make a proprietary LCD work??
I'm new to using LCD's on the front of my cases and such, and I'm starting off with a complicated project.
I bought some Network Engines Roadster 1U cases and they have an LCD on the front of the case to read out info and such. Now, I've modded the case so a regular ATX motherboard can fit in it along with a standard 1U power supply. Now I'm trying to get the LCD functioning in any way.
Here is what the LCD looks like:
Front:
Back:
Back w/ ribbon:
Here is what I think the pinout configuration is; I found this by going thru the user's manual, I figured it would probably be of some help...
And here is what it looks like when it assembeled on the front and what each button/LED is for:
At this point, I would just like to find a way to make it display things on the lcd, I'm not too concerned about making the power, NIC, HDD, any of the other LEDs, or buttons do anything at this point. Later on I may want to do that though, if possible.
The original proprietary motherboard that was in the 1U case had a header to connect the other end of the ribbon from the LCD, the LCD was used to control almost every function of the server, it powered the server on, power off, reboot, IP address, ect, it was pretty crazy but cool. Obviously, the new motherboard I put in the case doesn't have this header, so I need to find a way to connect it.
If anyone could provide me some help or direction on how to make this work or where to go and find info on how to make this work, it would be greatly appreciated.
Front:
Back:
Back w/ ribbon:
