Need help for OPTERX's obsolete LCD
amit02204
Hi All,
Sorry for creating new same looking thread , but my needs and his needs and solutions are different.
I am having a device with OPTREX's Graphic LCD DMF-5001NYL(datasheet can found at : http://www.datasheetarchive.com/pdf-datasheets/Datasheets-24/DSA-464969.pdf)(Datasheet also included).
Now my problem is this LCD has gone bad and I can not read any thing from this LCD.
so can anybody help me in finding the exact replacement of this LCD which is having
160 x 128 , 20 pin interface , 8-bit data bus, no backlight , 64k RAM .
I am in need of replacement of OPTREX's "DMF-5001NYL" LCD(alternative LCD for this).
Please ask any aditional information required.
Waiting for responses.
Regards
Amit02204
  • DMF5001NYL.pdf
CF Support2
It looks like our CFAG160128B series is similar in size and specifications. We currently manufacture and stock two variants. The CFAG160128B-YYH-TZ:
http://www.crystalfontz.com/product/CFAG160128B-YYH-TZ
and CFAG160128B-TMI-TZ:
http://www.crystalfontz.com/product/CFAG160128B-TMI-TZ
I noticed that the Optrex's display has a 9:00 o'clock viewing angle. Our displays have a 6 o'clock viewing angle. Our module has the same controller, same pin out, and similar electrical and optical characteristics. The CFAG160128B series should work as replacement.
amit02204
Some more queries
Thanks for your quick response.
I have some more queries:-
Does the initialization sequence of DMF-5001NYL and the LCDs you provided are same?
Current requirement for DMF-5001NYL is 20ma and for your LCDs is 40 ma.
Is it ok to connect these LCDs in place of DMF-5001NYL? Correct me if I am wrong.
suppose I place my order on 2nd oct than what is the earliest approximate date
I can get LCD. We are located in chennai,INDIA and
can you provide some value for custom duty also.
Please provide the full pricing for LCDs for 1 piece and for bulk order
(which includes LCD cost + courier charge + custom duty + etc).
Regards
Amit02204
