Mobo Header Q Again! Last one!
archon
I just want to be ABSOLUTELY sure but WRUSBY03 (USB A(male) to 2mm connector cable) Will connect the LCD to the motherboard (compatible with all motherboards) and will power the lcd as well, right?
This is for the 634 USB LCD.
archon
What you will get looks exactly like this:
This end plugs into the display:
And this end plugs into your motherboard (or case, or a powered USB hub):
There is only one connection needed on any of our USB displays. Both power and data is provided over this connection.
archon
When will the direct cable from the LCD to the motherboard be released? Your previous posts stated mid march.
phpguru
