Re: jc634 MBM Screens
[r00-i02]
length=2
id=2508810313
the: id=2508810313
to id=1085864257
(from your posted MBM.ini file)?
Your description sounds like you did but I just wanted to make sure...
Have you copied the created data_mbm.ini from the mbm_ini_creator.exe program to your C:\Program Files\CrystalControl2\cc2-service directory and renamed it to cc2_mbm.ini?
Do you see any lines like this in your cc2_mbm.log file;
Thu 13 23:01:25 NOTICE ini_read_dword: value found: sensor64->name_id = 2465774537
Or do you see something like this in the cc2_mbm.ini file;
Thu 13 23:01:21 NOTICE log_start: Logging started
Thu 13 23:01:21 NOTICE timer_calibrate: timer ticks/sec: 2870131632.6311
Thu 13 23:01:22 CRITICAL ini_read: Could not open config file "C:\Program Files\CrystalControl2\cc2-service\cc2_mbm.ini"
These things are addicting eh? How many times did you think about it at work?
From the JC_mbm_Temps.2002 (631 Screen file)... did you change in this section (for example)Jutias said:Need help with setting up the MBM temp screens.
Changed the id's to my value id's and no go.
Even set all your temp id's to my CPU temp value id and no go.
Screens come up in my 631 and 634 but no temps.
I think I need a mbm screen setup for Dummys.
Took a screen shot of my mbm ini file and attached it.
thanks
Jutias
[r00-i02]
length=2
id=2508810313
the: id=2508810313
to id=1085864257
