There is directory under CC2 named mbm-ini-gen. Run the mbm_ini_creator.exe file. This will create a .ini file for you (you must have MBM installed and running when you do this). If I remember correctly, you have to rename it to cc2_mbm.ini. Just make the file is called cc2_mbm.ini, at least. Move it your Crystalcontrol2\cc2-service directory. Part of the file that I created when I had MBM installed is as follows:
[sensor00]
comment="Temp Sensor 1 - Case"
name_id=1213913833
value_id=1895855
min_id=2748208265
max_id=689454350
[sensor01]
comment="Temp Sensor 2 - CPU"
name_id=4055797019
value_id=2508810313
min_id=848618958
max_id=42943802
[sensor02]
comment="Temp Sensor 3 - Sensor 3"
name_id=2780136986
value_id=3044718348
min_id=2621479887
max_id=1388419889
Note your name_id values. You will have to edit your (my) screen files to put in your name_id values. You may have to experiment with your names (i.e., CPU) and the name_id values to make sure you have them matched correctly.
That should be it.
If you still have problems, let me know. I may end up having to reinstall MBM and going thru the process (in case I missed any steps!).
